bouton panier avec nbr et prix
Messagepar plugeplay » 14 Nov 2012, 16:45
Salut à tous,
J'essaye actuellement d'ajouter la partie actualisée du module panier sur le bouton panier de mon menu... (est-ce clair? :geek: )
voici pour l'instant le code de mon fichier xml
<!-- modifications panier-menu -->
   <file name="catalog/language/english/common/header.php">
      <operation>
         <search position="after"><![CDATA[
     // Text
         ]]></search>
         <add><![CDATA[
      $_['text_items']      = '&nbsp;[&nbsp;%s - %s&nbsp;]';
         ]]></add>
      </operation>
   </file>
    <file name="catalog/language/french/common/header.php">
      <operation>
     // Text
         ]]></search>
         <add><![CDATA[
         ]]></add>
      </operation>
   </file>
    <file name="catalog/language/spanish/common/header.php">
      <operation>
     // Text
         ]]></search>
         <add><![CDATA[
         ]]></add>
      </operation>
   </file>
   <file name="catalog/controller/common/header.php">
      <operation>
     $this->data['text_checkout'] = $this->language->get('text_checkout');
         ]]></search>
         <add><![CDATA[
      $this->data['totals'] = $total_data;
      $this->data['text_items'] = sprintf($this->language->get('text_items'), $this->cart->countProducts() + (isset($this->session->data['vouchers']) ? count($this->session->data['vouchers']) : 0), $this->currency->format($total));
         ]]></add>
      </operation>
   </file>
   <file name="catalog/view/theme/default/template/common/header.tpl">
         <operation>
  <div class="links"><a href="<?php echo $home; ?>"><?php echo $text_home; ?></a><a href="<?php echo $wishlist; ?>" id="wishlist-total"><?php echo $text_wishlist; ?></a><a href="<?php echo $account; ?>"><?php echo $text_account; ?></a><a href="<?php echo $shopping_cart; ?>"><?php echo $text_shopping_cart; ?></a><a href="<?php echo $checkout; ?>"><?php echo $text_checkout; ?></a></div>
         ]]></search>
         <add><![CDATA[
         ]]></add>
      </operation>
       <operation>
            ]]></search>
            <add><![CDATA[
     <a href="<?php echo $shopping_cart; ?>"><?php echo $text_shopping_cart; ?><?php echo $text_items; ?></a>
            ]]></add>
      </operation>
   </file>
et le résultat en image
et l'erreur:
Notice: Undefined variable: total_data in /homez.577/****/www/vqmod/vqcache/vq2-catalog_controller_common_header.php on line 60Notice: Undefined variable: total in /homez.577/*****/www/vqmod/vqcache/vq2-catalog_controller_common_header.php on line 61
Félicitations, vous avez ajouté Canon EOS 5D à votre panier !
Je suis un peu coincé. Je n'arrive pas à appeler la class "d'actualisation du panier" depuis le header. Il n'aditionne donc pas les prix, seulement le nombre de produit, mais je suis obligé d'actualiser la page pour actualiser le panier...
Je suis preneur de tout conseil.
os x (Apple/mac)
serveur local MAMP
Serveur mutualisé OVH
version 1.5.2
HTML module
VQmod
plugeplay
Re: bouton panier avec nbr et prix
Messagepar LeorLindel » 14 Nov 2012, 19:04
Il te suffit d'utiliser les éléments contenus dans le fichier catalog/controller/module/cart.php pour déclarer tes variables dans ton fichier xml.
Messagepar plugeplay » 14 Nov 2012, 19:19
Merci de ta réponse! Je creuse un peu par là mais sans grande réussite. Je vais me relire, parce qu'il suffit vraiment d'un rien pour que ça ne fonctionne pas :D
os x (Apple/mac)
serveur local MAMP
version 1.5.2
HTML module
VQmod
plugeplay
Messagepar LeorLindel » 14 Nov 2012, 22:46
Si tu trouves ta réponse, j'espère que tu en feras profiter la communauté et que tu n'omettras pas de mette la petite icône de résolution dans le titre initial du sujet.
Messagepar plugeplay » 14 Nov 2012, 23:20
Absolument! :D
Voici donc le problème en partie résolu avec ces lignes suivantes
      <operation>
         <search position="before"><![CDATA[
     $this->data['text_home'] = $this->language->get('text_home');
         ]]></search>
         <add><![CDATA[
      $this->load->model('setting/extension');
      $total_data = array();
      $total = 0;
      $taxes = $this->cart->getTaxes();
      $sort_order = array();
      $results = $this->model_setting_extension->getExtensions('total');
      foreach ($results as $key => $value) {
         $sort_order[$key] = $this->config->get($value['code'] . '_sort_order');
      array_multisort($sort_order, SORT_ASC, $results);
      foreach ($results as $result) {
         if ($this->config->get($result['code'] . '_status')) {
            $this->load->model('total/' . $result['code']);
            $this->{'model_total_' . $result['code']}->getTotal($total_data, $total, $taxes);
         foreach ($total_data as $key => $value) {
            $sort_order[$key] = $value['sort_order'];
         array_multisort($sort_order, SORT_ASC, $total_data);
      ]]></add>
      </operation>
      <operation>
         ]]></search>
         <add><![CDATA[
         ]]></add>
      </operation>
   </file>
         <operation>
         ]]></search>
         <add><![CDATA[
         ]]></add>
      </operation>
       <operation>
            ]]></search>
            <add><![CDATA[
     <a href="<?php echo $shopping_cart; ?>"><?php echo $text_shopping_cart; ?><span style="font-size:x-small;display:block;float:right;"><?php echo $text_items; ?></span></a>
            ]]></add>
      </operation>
   </file>
les modifs <span> dans le header.tpl sont juste esthétiques, le tout étant d'avoir <?php echo $text_items; ?> dans la balise adéquoite.
Par contre, il reste un souci non résolu: l'actualisation du panier en temps réél... Autant quand on supprime, pas de souci, autant quand on ajoute, il ne se passe rien. Il y a donc d'autres lignes à rajouter, mais lesquelles? zat ize zeu kwestion :D
EDIT:S'il y a une solution pour l'actualisation du panier, je suis preneur...
os x (Apple/mac)
serveur local MAMP
version 1.5.2
HTML module
VQmod
plugeplay
