Optimisation .htaccess
Messagepar Canou83 » 17 Jan 2014, 15:00
Bonjour, toujours dans un soucis d'amélioration de la vitesse du site, et en parallèle à l'amélioration de la BDD et des requêtes, j'ai aussi travaillé sur mon .htaccess.
Options +FollowSymlinks
# Prevent Directoy listing
Options -Indexes
## EXPIRES CACHING ##
<IfModule mod_expires.c>
ExpiresActive On
ExpiresByType image/jpg "access plus 1 week"
ExpiresByType image/jpeg "access plus 1 week"
ExpiresByType image/gif "access plus 1 week"
ExpiresByType image/png "access plus 1 week"
ExpiresByType text/css "access plus 1 week"
ExpiresByType application/pdf "access plus 1 week"
ExpiresByType text/x-javascript "access plus 1 week"
ExpiresByType application/x-shockwave-flash "access plus 1 week"
ExpiresByType image/x-icon "access plus 1 week"
ExpiresDefault "access plus 1 week"
</IfModule>
# compress text, HTML, JavaScript, CSS, and XML
AddOutputFilterByType DEFLATE text/plain
AddOutputFilterByType DEFLATE text/html
AddOutputFilterByType DEFLATE text/xml
AddOutputFilterByType DEFLATE text/css
AddOutputFilterByType DEFLATE application/xml
AddOutputFilterByType DEFLATE application/xhtml+xml
AddOutputFilterByType DEFLATE application/rss+xml
AddOutputFilterByType DEFLATE application/javascript
AddOutputFilterByType DEFLATE application/x-javascript
# remove browser bugs
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4\.0[678] no-gzip
BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
Header append Vary User-Agent
<ifModule mod_headers.c>
    Header set Connection keep-alive
</ifModule>
# SEO URL Settings
RewriteEngine On
RewriteBase /
RewriteRule ^sitemap.xml$ index.php?route=feed/google_sitemap [L]
RewriteRule ^googlebase.xml$ index.php?route=feed/google_base [L]
RewriteCond %{REQUEST_URI} !.*\.(ico|gif|jpg|jpeg|png|js|css)
RewriteCond %{HTTP_HOST} ^aquamagasin.com$
RewriteRule ^(.*) http://www.aquamagasin.com/$1 [QSA,L,R=301]
RewriteCond %{QUERY_STRING} ^(.*)common/home(.*)$
RewriteRule ^index\.php$ http://www.aquamagasin.com? [L,R=301]
### Additional Settings that may need to be enabled for some servers
### Uncomment the commands by removing the # sign in front of it.
### If you get an "Internal Server Error 500" after enabling any of the following settings, restore the # as this means your host doesn't allow that.
# 1. If your cart only allows you to add one item at a time, it is possible register_globals is on. This may work to disable it:
# php_flag register_globals off
# 2. If your cart has magic quotes enabled, This may work to disable it:
# php_flag magic_quotes_gpc Off
# 3. Set max upload file size. Most hosts will limit this and not allow it to be overridden but you can try
# php_value upload_max_filesize 999M
# 4. set max post size. uncomment this line if you have a lot of product options or are getting errors where forms are not saving all fields
# php_value post_max_size 999M
# 5. set max time script can take. uncomment this line if you have a lot of product options or are getting errors where forms are not saving all fields
# php_value max_execution_time 200
# 6. set max time for input to be recieved. Uncomment this line if you have a lot of product options or are getting errors where forms are not saving all fields
# php_value max_input_time 200
# 7. disable open_basedir limitations
# php_admin_value open_basedir none
J'ai des résultats honorables et améliorés :
Est ce que j'ai oublié quelque chose dans mon .ht.access ? des choses à changer ?
Faut-il que je mette également (ou pas) :
Options -Indexes
# Prevent Direct Access to files
<FilesMatch "\.(tpl|ini|log)">
 Order deny,allow
 Deny from all
</FilesMatch>
J'ai aussi dans catalog/view/theme/[YOUR THEME]/common/header.tpl rajouté
<script [color=#FF0000]async[/color] type="text/javascript" src="catalog/view/javascript/common.js"></script>
dans la dizaine de ligne de code identiques
+ Ajouté les dimensions d'images dans system/library/response.php
//Q: Add width/height tags to all images for Google Page Speed tip:
//http://code.google.com/speed/page-speed/docs/rendering.html#SpecifyImageDimensions
preg_match_all('/<img[^>]+>/i', $this->output, $result);
$img = array();
foreach($result[0] as $img_tag) {
preg_match_all('/(width|height|src)=("[^"]*")/i',$img_tag, $img[$img_tag]);
foreach ($img as $k => $info) {
if (count($info) == 3 && $info[1][0] == 'src') {
//if (curl_init(str_replace('"', '', $info[2][0]))) {
$imgfile = str_replace('"', '', $info[2][0]);
$imgfile = str_replace(HTTP_SERVER, DIR_IMAGE . '../', $imgfile);
$imgfile = str_replace(HTTPS_SERVER, DIR_IMAGE . '../', $imgfile);
if (file_exists($imgfile)) {
$image_info = getImageSize(str_replace('"', '', $imgfile));
$k = trim($k, '/>');
$k = trim($k, '>');
$this->output = str_replace($k, ($k . ' ' . $image_info[3]), $this->output);
+ L'ouverture multiple en rajoutant ça dans le .htacess :
</ifModule>
Mais par contre ayant un serveur mutu, je ne sais pas ou mettre :
KeepAlive On
MaxKeepAliveRequests 50
KeepAliveTimeout 7
Merci pour vos conseils.
Opencart 2.3.0.3 en fr
Journal 2
Canou83
Re: Optimisation .htaccess
Messagepar Canou83 » 26 Jan 2014, 14:26
Nouvelles performances après quelques réglages, mais il reste de la marge. Je suis preneur de conseils :)
Éliminer les codes JavaScript et CSS qui bloquent l'affichage du contenu au-dessus de la ligne de flottaison
Votre page contient 1 ressources de script et 3 ressources CSS qui bloquent l'affichage de votre page, et donc le retardent.
Aucune partie du contenu situé au-dessus de la ligne de flottaison sur votre page n'a pu être affichée avant que le chargement des ressources suivantes n'ait été terminé. Essayez de différer le chargement des ressources qui bloquent votre page, de les charger de manière asynchrone, ou d'intégrer les parties essentielles de ces ressources directement dans le code HTML.
Supprimez les ressources JavaScript qui bloquent l'affichage :
http://www.aquamagasin.com/…atalog/view/javascript/jquery.cluetip.js
Optimisez l'affichage des styles CSS pour les URL suivantes :
http://www.aquamagasin.com/…jzs6y3mn52will2n5xw2ltdonzq/combined.css
https://fonts.googleapis.com/css?family ... +Condensed
http://www.aquamagasin.com/…talog/view/javascript/jquery.cluetip.css
Réduire la taille des ressources JavaScript
En compressant votre code JavaScript, vous pouvez libérer de nombreux octets de données et réduire les délais de téléchargement, d'analyse et d'exécution.
Réduisez la taille des ressources JavaScript suivantes afin de gagner 20,5 Ko (réduction de 22 %).
Une réduction de la taille de http://www.aquamagasin.com/…e/Universum/js/count/jquery.countdown.js pourrait libérer 3,6 Ko (réduction de 43 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…e/Universum/js/flex/jquery.flexslider.js pourrait libérer 3,2 Ko (réduction de 37 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…atalog/view/javascript/jquery.cluetip.js pourrait libérer 3,1 Ko (réduction de 44 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…cript/jquery/colorbox/jquery.colorbox.js pourrait libérer 3,1 Ko (réduction de 40 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…eme/Universum/js/liteaccordion.jquery.js pourrait libérer 2,2 Ko (réduction de 49 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…eme/Universum/js/cloud-zoom.1.0.2.min.js pourrait libérer 1,9 Ko (réduction de 44 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…/theme/Universum/js/jquery.easing.min.js pourrait libérer 1 015 o (réduction de 53 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…ript/jquery/ui/external/jquery.cookie.js pourrait libérer 932 o (réduction de 69 %) après compression.
Une réduction de la taille de http://ajax.googleapis.com/…ax/libs/jqueryui/1.8.16/jquery-ui.min.js pourrait libérer 885 o (réduction de 2 %) après compression.
Une réduction de la taille de http://www.aquamagasin.com/…w/theme/Universum/js/scrolltopcontrol.js pourrait libérer 674 o (réduction de 42 %) après compression.
Exploiter la mise en cache du navigateur
Si vous définissez une date d'expiration ou une durée de validité maximale pour les ressources statiques dans les en-têtes HTTP, vous indiquez au navigateur d'aller chercher les ressources déjà téléchargées sur le disque local plutôt que sur le réseau.
Exploitez la mise en cache du navigateur pour les ressources suivantes pouvant être mises en cache :
http://platform.twitter.com/…0cac0aa5abbe2c1b5c5cd368d398.default.css (délai d'expiration non spécifié)
https://cdn.syndication.twimg.com/…926478336_1&suppress_response_codes=true (60 secondes)
http://connect.facebook.net/en_US/all.js (20 minutes)
http://platform.twitter.com/widgets.js (30 minutes)
Autoriser la compression
En compressant vos ressources avec "gzip" ou "deflate", vous pouvez réduire le nombre d'octets envoyés sur le réseau.
Autorisez la compression des ressources suivantes afin de réduire le volume de données transférées de 17,1 Ko (réduction de 71 %).
La compression de http://www.facebook.com/…false&header=false&appId=164073580341460 pourrait libérer 17,1 Ko (réduction de 71 %).
Raison: Remplacement des balises de code par des balises de commentaires
Journal 2
Canou83
