[Résolu] Journal d'erreurs
Messagepar soleildusud » 18 Aoû 2011, 09:24
Depuis l'installation de site en line je note des erreurs récurrentes dans le journal d'erreur.
Pouvez vous m'aider à comprendre à quoi elles sont dues et ce que je dois faire pour ne plus avoir ces erreurs ?
2011-08-16 2:42:34 - PHP Warning: fopen(/xxxx/yyyy/www/system/cache/cache.category.25.2.0.1313458668) [<a href='function.fopen'>function.fopen</a>]: failed to open stream: No such file or directory in /xxxx/yyyy/www/system/library/cache.php on line 26
2011-08-16 2:42:34 - PHP Warning: filesize() [<a href='function.filesize'>function.filesize</a>]: stat failed for /xxxx/yyyy/www/system/cache/cache.category.25.2.0.1313458668 in /xxxx/yyyy/www/system/library/cache.php on line 27
2011-08-16 2:42:34 - PHP Warning: fread(): supplied argument is not a valid stream resource in /xxxx/yyyy/www/system/library/cache.php on line 27
2011-08-16 2:42:34 - PHP Warning: fclose(): supplied argument is not a valid stream resource in /xxxx/yyyy/www/system/library/cache.php on line 29
2011-08-16 2:42:35 - PHP Warning: fopen(/xxxx/yyyy/www/system/cache/cache.category.29.2.0.1313458668) [<a href='function.fopen'>function.fopen</a>]: failed to open stream: No such file or directory in /xxxx/yyyy/www/system/library/cache.php on line 26
2011-08-16 2:42:35 - PHP Warning: filesize() [<a href='function.filesize'>function.filesize</a>]: stat failed for /xxxx/yyyy/www/system/cache/cache.category.29.2.0.1313458668 in /xxxx/yyyy/www/system/library/cache.php on line 27
2011-08-16 2:42:35 - PHP Warning: fread(): supplied argument is not a valid stream resource in /xxxx/yyyy/www/system/library/cache.php on line 27
2011-08-16 2:42:35 - PHP Warning: fclose(): supplied argument is not a valid stream resource in /xxxx/yyyy/www/system/library/cache.php on line 29
2011-08-16 2:42:34 - PHP Warning: fopen(/xxxx/yyyy/www/system/cache/cache.category.33.2.0.1313458668) [<a href='function.fopen'>function.fopen</a>]: failed to open stream: No such file or directory in /xxxx/yyyy/www/system/library/cache.php on line 26
2011-08-16 2:42:34 - PHP Warning: filesize() [<a href='function.filesize'>function.filesize</a>]: stat failed for /xxxx/yyyy/www/system/cache/cache.category.33.2.0.1313458668 in /xxxx/yyyy/www/system/library/cache.php on line 27
2011-08-17 17:00:50 - PHP Warning: unlink(/xxxx/yyyy/www/system/cache/cache.category.33.2.0.1313596850) [<a href='function.unlink'>function.unlink</a>]: No such file or directory in /xxxx/yyyy/www/system/library/cache.php on line 54
J'utilise également les outils webmaster de google et dans les erreurs d'exploration il m'indique :
monsite.com/function.filesize 404(introuvable) 1pages 12 août 2011
monsite.com/function.unlink 404(introuvable) 2pages 12 août 2011
monsite.com/function.fopen 404(introuvable) 1pages 12 août 2011
là encore que faire pour qu'il ne me prenne pas en compte ces functions dont je n'ai pas encore compris la fonction ;-)
soleildusud
Re: Journal d'erreurs
Messagepar LeorLindel » 18 Aoû 2011, 10:05
Par le biais de ton logiciel FTP, met ce dossier "/system/cache" en "droit en écriture" (777) puis supprimes tous les fichiers se trouvant à l'intérieur de celui-ci (/system/cache).
Dans ton admin, va dans ton journal d'erreurs et remet à zéro celui-ci.
Constate après cela, si il y a des modifications après utilisation de ton site.
Messagepar soleildusud » 26 Aoû 2011, 09:35
Merci pour ta réponse
ça a marché pour une partie mais maintenant j'ai ces erreurs :
2011-08-24 20:21:48 - PHP Warning:  fread(): supplied argument is not a valid stream resource in /xxxx/yyyy/www/system/library/cache.php on line 27
2011-08-24 20:21:48 - PHP Warning:  fclose(): supplied argument is not a valid stream resource in /xxxx/yyyy/www/system/library/cache.php on line 29
et
2011-08-25 17:22:45 - PHP Warning:  imagejpeg(): supplied argument is not a valid Image resource in /xxxx/yyyy/www/system/library/image.php on line 43
2011-08-25 17:22:45 - PHP Warning:  imagedestroy(): supplied argument is not a valid Image resource in /xxxx/yyyy/www/system/library/image.php on line 50
Que dois je faire pour ne plus avoir ces erreurs?
Pourquoi j'obtiens ces erreurs?
Merci par avance
soleildusud
Messagepar LeorLindel » 26 Aoû 2011, 09:51
soleildusud a écrit:Que dois je faire pour ne plus avoir ces erreurs ?
Est ce que ton répertoire system/cache est en chmod 777 ou 755 ?
Si ce n'est pas le cas, mets ces droits.
Si c'est le cas ou si cela continue malgré le changement de chmod, contacte ton hébergeur.
Messagepar soleildusud » 26 Aoû 2011, 10:37
Oui mon répertoire system/cache est bien en chmod 777
Mais les nouvelles erreurs que j'ai concerne system/library/cache.php et non pas system/cache
les 2 lignes concernées de system/library/cache.php sont :
$cache = fread($handle, filesize($file));
fclose($handle);
et les 2 lignes concernées de system/library/image.php sont :
imagejpeg($this->image, $file, $quality);
imagedestroy($this->image);
Dois je aussi changer les droits du répertoire library?
soleildusud
Messagepar LeorLindel » 26 Aoû 2011, 10:39
soleildusud a écrit:Dois je aussi changer les droits du répertoire library ?
Non !
Comme je te l'ai dit ci-dessus, contacte alors ton hébergeur.
Malgré tout, tu n'as pas lieu de t'alarmer plus que ça, cela ne reste que des avertissements et non des erreurs (warning et non error).
PS : Pourras-tu, les prochaines fois, mettre le code dans les balises destinées à cet effet [Code], ceci afin d'obtenir une meilleure visibilité. J'ai corrigé ton post initial.
