problème avec la page d'administration
Messagepar zied666 » 07 Mar 2012, 23:38
Salutation
j ai hebergé mon site dans un serveur apres la transfert des fichiers, configuré la base mysql et j'ai modifié le chmod de quelques dossiers puisque le serveur est Linux
mais, j'arrive pas a acceder a la page de l'administration http://www.mon-site.com/admin pourtant ilya aucun probleme avec mon site
concernant les fichiers de configurations
config.php
<?php
// HTTP
define('HTTP_SERVER', 'http://www.orientaldelice.com/');
define('HTTP_IMAGE', 'http://www.orientaldelice.com/image/');
define('HTTP_ADMIN', 'http://www.orientaldelice.com/admin/');
// HTTPS
define('HTTPS_SERVER', 'https://www.orientaldelice.com/');
define('HTTPS_IMAGE', 'https://www.orientaldelice.com/image/');
define('HTTPS_ADMIN', 'http://www.orientaldelice.com/admin/');
// DIR
define('DIR_APPLICATION', '/var/www/vhosts/orientaldelice.com/httpdocs/catalog/');
define('DIR_SYSTEM', '/var/www/vhosts/orientaldelice.com/httpdocs/system/');
define('DIR_DATABASE', '/var/www/vhosts/orientaldelice.com/httpdocs/system/database/');
define('DIR_LANGUAGE', '/var/www/vhosts/orientaldelice.com/httpdocs/catalog/language/');
define('DIR_TEMPLATE', '/var/www/vhosts/orientaldelice.com/httpdocs/catalog/view/theme/');
define('DIR_CONFIG', '/var/www/vhosts/orientaldelice.com/httpdocs/system/config/');
define('DIR_IMAGE', '/var/www/vhosts/orientaldelice.com/httpdocs/image/');
define('DIR_CACHE', '/var/www/vhosts/orientaldelice.com/httpdocs/system/cache/');
define('DIR_DOWNLOAD', '/var/www/vhosts/orientaldelice.com/httpdocs/download/');
define('DIR_LOGS', '/var/www/vhosts/orientaldelice.com/httpdocs/system/logs/');
define('DIR_ADMIN', '/var/www/vhosts/orientaldelice.com/httpdocs/admin/');
et admin/config.php
<?php
// HTTP
define('HTTP_SERVER', 'http://www.orientaldelice.com/admin/');
define('HTTP_CATALOG', 'http://www.orientaldelice.com/');
// HTTPS
define('HTTPS_SERVER', 'https://www.orientaldelice.com/admin/');
// DIR
define('DIR_APPLICATION', '/var/www/vhosts/orientaldelice.com/httpdocs/admin');
define('DIR_LANGUAGE', '/var/www/vhosts/orientaldelice.com/httpdocs/admin/language/');
define('DIR_TEMPLATE', '/var/www/vhosts/orientaldelice.com/httpdocs/admin/view/template/');
define('DIR_CATALOG', '/var/www/vhosts/orientaldelice.com/httpdocs/catalog/');
pour plus d'info quand j’accède a la page administration je trouve une page vide sans erreurs
et merci d'avance
zied666
- Hébergeur : ovh
- Modules installés
- Template installé : black_justin2
- Version du PHP : 5.3
zied666
Re: problème avec la page d'administration
Messagepar LeorLindel » 08 Mar 2012, 04:18
Bonjour et bienvenue,
Je constate que tu n'as pas lu, ni respecté les points importants complétant ma signature concernant la signature et les balises de mise en forme.
Je t'encourage donc à le faire, sinon nous ne pourrons pas te répondre.
T'en remerciant par avance.
Messagepar zied666 » 16 Mar 2012, 15:47
desolé pour le retard mais stp j'ai toujours le même probleme :|
- Hébergeur : ovh
- Modules installés
zied666
Messagepar LeorLindel » 16 Mar 2012, 16:00
Cela à l'air d'un problème de redirection de ton hébergement. Je te conseille de consulter les forums d'OVH ou de prendre contact avec eux.
Je dis cela car l'icône composant l'onglet du navigateur correspond à l'icône d'OVH.
Messagepar LeorLindel » 17 Mar 2012, 05:56
zied666 a écrit:pour plus d'info quand j’accède a la page administration je trouve une page vide sans erreurs
Si tu veux visualiser les erreurs générées, il faut que tu mettes dans ton fichier ".htaccess", cette ligne :
display_errors = on
Mais une fois ton site mis en production, il faut mieux tenir compte de cet article.
Messagepar zied666 » 27 Mar 2012, 12:14
j'ai trouvé ou le probleme,
il me manque juste
define('DIR_APPLICATION', '/var/www/vhosts/orientaldelice.com/httpdocs/admin/');
merci quand même
- Hébergeur : ovh
- Modules installés
zied666
Messagepar LeorLindel » 27 Mar 2012, 12:26
Merci de ce retour.
RAPPEL
L'icône Image se met dans le titre initial du sujet, sinon cela n'a aucun intérêt.
