[Résolu] Module Sales-Report 1.2 - Warnings Error messages
Messagepar lucho69 » 13 Avr 2011, 08:02
bonjour
j'ai acheté et installé le module "Export Ventes" compatible 1.4.7, 1.4.8, 1.4.9
j'ai suivi, je pense toute la procédure d'install
Lorsque je vais Rapports / Export des Ventes, j'ai un 1ere message Warning
Notice: Undefined index: token in /var/www/monsite.com/admin/controller/report/export.php on line 42Notice: Undefined index: token in /var/www/monsite.com/admin/controller/report/export.php on line 48Notice: Undefined index: token in /var/www/monsite.com/admin/controller/report/export.php on line 244
mais l'ecran de sélection des critères s'affiche correctement
aussi je fais la sélection date, statut etc...
un clic sur export CSV ou XLS génère un ecran d'erreur
Notice: Undefined index: token in /var/www/xxxxxxxx.com/admin/controller/report/export.php on line 42Notice: Undefined index: token in /var/www/xxxxxxxxcom/admin/controller/report/export.php on line 48Warning: Cannot modify header information - headers already sent by (output started at /var/www/xxxxxxxx.com/admin/index.php:74) in /var/www/xxxxxxxx.com/admin/view/template/report/export_order_list.xls.tpl on line 6Warning: Cannot modify header information - headers already sent by (output started at /var/www/xxxxxxxx.com/admin/index.php:74) in /var/www/xxxxxxxx.com/admin/view/template/report/export_order_list.xls.tpl on line 7Warning: Cannot modify header information - headers already sent by (output started at /var/www/xxxxxxxx.com/admin/index.php:74) in /var/www/xxxxxxxx.com/admin/view/template/report/export_order_list.xls.tpl on line 8Warning: Cannot modify header information - headers already sent by (output started at /var/www/xxxxxxxx.com/admin/index.php:74) in /var/www/xxxxxxxxs.com/admin/view/template/report/export_order_list.xls.tpl on line 93#c0c0c04#ff000090001386024075FalseFalse
une idée de ce qui ne va pas?
Luc
Opencart 1.5.6.4_Fr à Opencart 2.x
lucho69
Re: Module Sales-Report 1.2 - Warnings Error messages
Messagepar LeorLindel » 13 Avr 2011, 09:48
Il serait utile que tu remplisses ta signature (Lire la mienne), si tu désires que l'on t'apporte de l'aide.
RESOLU Module Sales-Report 1.2 - Warnings Error messages
Messagepar lucho69 » 13 Avr 2011, 19:56
je penserais à le mettre dans chaque Post car dans la signature ..comme j'ai du 1.4.7, 1.4.8, 1.4.9 , du FR du EN et même du ES (pour un module mercamania qui est la filiale de leguide.com , j'ai acheté le module mercamania et en qq substitutions sur le ficher XML , on a un export leguide.com
Olivier, l'auteur du module m'a répondu :
erreur sur 1.4.7 car la notion de token a été introduite dans la version d'après,
il vous suffit d'éditer les fichiers php du module et de remplacer :
toutes les occurences :
'href' => HTTPS_SERVER . 'index.php?route=common/home&token=' . $this->session->data['token'],
par :
'href' => HTTPS_SERVER . 'index.php?route=common/home',
pb corrigé
Je conseille ce module Addon, il est excellent
Lucho69 - opencart 1.4.7 FR - Module Sales-Report 1.2
lucho69
